co-tron components limited
partex cable ties
...Cable Ties text...
  • Non-Releasable Nylon 6.6 Cable Ties
    Partex standard range of high quality Nylon 6.6 cable ties. Available in sizes from 80mm to 1030mm.
  • Coloured Cable Ties
    Red, Blue, Green, Yellow and Silver coloured cable ties.
  • Special Purpose Cable Ties
    Screw and push mountable cable ties, and cable tray fixing ties.
  • Marker Cable Ties
    Marker ties and Identification tags for securing and marking bundles of cable.
  • Cable Tie Bases and Mounts
    Cable tie bases and saddle type mounts with adhesive backing and/or screw mounting hole.
  • Cable Fixings
    Self-adhesive cable clips and screw / bolt mounted p-clips.
    NEW! - Cable tie masonry mounts.
  • Cable Tie with Stainless Steel Tooth
    A smooth cable tie with a stainless steel "barbed tooth" providing higher flexibility and higher resistance in demanding environments.
  • Stainless Steel Cable Ties
    Self locking stainless steel cable ties for tough environments. Available in both uncoated and pure polyester coated 316 grade stainless steel.
    NEW! - Red polyester coated stainless steel cable ties.
    NEW! - Ladder and heavy duty stainless steel cable ties.
    NEW! - Releasable coated stainless steel cable ties.
