co-tron components limited
HUMMEL
Cable glands for industrial applications in potentially explosive areas in polyamide, brass and stainless steel. The Ex-e and Ex-d certified cable glands are suitable exclusively for applications with non-armoured / reinforced cables.
  • HSK-Ex-e Standard Cable Glands
    Cable glands from the HSK-Ex Series are designed for use on electrical operating facilities in potentially explosive areas with protection type "e" in accordance with EN 60079-0 and EN 60079-7. Here you will find polyamide, brass and stainless steel threaded couplings with a variety of thread types, clamping ranges, thread lengths and temperature ranges.
  • HSK-Ex-e EMV Cable Glands
    Cable glands from the HSK-Ex Series are designed for use on electrical operating facilities in potentially explosive areas with protection type "e" in accordance with EN 60079-0 and EN 60079-7. Two different EMC protection systems ensure long contact life and easy-to-assemble application.
  • HSK Ex-e for special applications
    Cable glands from the HSK-Ex Series are designed for use on electrical operating facilities in potentially explosive areas with protection type "e" in accordance with EN 60079-0 and EN 60079-7. You will find here, among other things, cable glands of polyamide and brass with multiple and flat cable sealing inserts and also with additional strain relief (double cable grip).
  • HSK-Ex-d Standard Cable Glands
    Cable glands from the HSK-Ex-d Series are designed for use on electrical operating facilities in potentially explosive areas with protection type "e" and/or "d" in accordance with EN 60079-0, EN 60079-1 and EN 60079-7.
